11-25-2015 04:47 PM - edited 03-17-2019 05:01 AM
Does someone know about how many entries we can add per user?
Is there limit? If possible, I would like to make sure that on document.
11-25-2015 06:13 PM
Hi Shu,
The number is 99, its mentioned in the following doc for 88XX series IP phone
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/8831/9_3_3/english/user_guide/CS38_BK_U19ADA0C_00_userguide-8831/CS38_BK_U19ADA0C_00_userguide-8831_chapter_011.html#CS38_TP_P6E70310_00
11-25-2015 09:09 PM
Hi Manish,
Thank you very much for your reply.
I should have looked at the user guide.
How about 7800 series? Actually, I want to use Personal Diresctory with 7861.
I just looked at 7800 series user guide, but I can't see the number.
Is it the same number(99) with 7800? Should I try with actual system to know the number?
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/7811-7821-7841-7861/10-1/english/userguide/PA2D_BK_7A9531A8_00_7811-7821--7841--7861-ug-cucm/PA2D_BK_7A9531A8_00_7811-7821--7841--7861-ug-cucm_chapter_011.html#PA2D_TP_P144F632_00
11-25-2015 11:08 PM
For 7800 series the documentation is not clear about max entries in Personal directory
The personal directory contains a list of your personal contacts. You can assign fast-dial codes to your personal directory entries for fast-dialing.
You can set up your personal directory from your phone or from the Cisco Unified Communications Self Care Portal. Use your phone to assign fast-dial codes to the directory entries. For more information, see the Cisco Unified Communications Self Care Portal User Guide, located at http:/ /www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/useroptions/ 10_5_1/CUCM_BK_U437D0F8_00_self-care-user-guide-1051.html .
Basically if you open the device config page of a 78XX and click on Add/update speed dials you get 199 entries including fast dials.
This mens that you can have upto 199 entries added there and they can be accessed using fast dial codes assigned to them.
You may try on a 78XX in your cucm , add a quick 99 dummy entries followed by a couple of extra entries for fast dials and try accessing them from the phone.
Manish
