ANNOUNCEMENT - The community will be down for maintenace this Thursday August 13 from 12:00 AM PT to 02:00 AM PT. As a precaution save your work.
Highlighted
Personal Directory with External Contacts on Extension Mobility
A customer has a cisco 8865 phone device with extension mobility configuration and he has already configured some personal external contacts on his device profile at his the personal directory.
When someone (external contact) call him he cannot see the configured name on the phone device although the caller is already added on the personal directory.
Any idea how we can configure and see the name of an external, contact when they call us, which is already added at the personal directory on extension mobility device?
Thenks.
Argiris Verikios
#personal #directory #extension #mobility #device #profile #contact
2 ACCEPTED SOLUTIONS
Highlighted
VIP Engager
Re: Personal Directory with External Contacts on Extension Mobility
It is not a supported feature. Please check below post for more details:
https://community.cisco.com/t5/ip-telephony-and-phones/incoming-callers-name-from-personal-directory-in-cucm-12-x/td-p/3386236
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Highlighted
Hall of Fame Cisco Employee
You need a 3rd party solution to do that, the mapping you're asking about is only performed by Jabber, not by IP Phones.
java
if this helps, please rate
6 REPLIES 6
Highlighted
VIP Engager
Highlighted
Thanks Vaijanath!
Highlighted
Enthusiast
Actually, I misread the question and I'm incorrect...  Last reply was the right one..  My apologies!
Highlighted
java
Highlighted
Thanks Jaime!
Highlighted
Beginner
Beginner
If you are open to 3rd Party solutions then you can checkout "MARS Directory & Caller Details" application for Cisco CUCM
http://www.parsec-tech.com/parsecapplications.html
