02-18-2011 02:18 AM - edited 03-16-2019 03:32 AM
I`m sure i`m just missing something here ,but how can i allow my users to create their own personal SD`s from the web gui ? When i go to web gui and login as user i only see the Line Speed dials eg. adding a SD on a line button ,theren is no Personal SD section ?
02-18-2011 06:02 AM
Ryanard,
When logged in as the user you should see fast dials under the user options; from there you should be able to add the speed dials.
Paul
02-20-2011 10:27 PM
I don`t have user options menu only phone options ?
02-21-2011 05:27 AM
My mistake Rynard, I think I misread your original post thinking you were on CUCM 7 instead of CME.
