1293
cwilliams1111
Beginner
phone 7942 not receiving outside calls
Incoming calls originating outside our network are not being received at desk extension.  How do we fix this issue?
1 ACCEPTED SOLUTION
Jaime Valencia
Hall of Fame Cisco Employee
Not sure what you think this is, but this is a public forum for VoIP with Cisco technologies, not a helpdesk in which you open any kind of tickets. It's really meant for the Voice Admins to post here, not end users with problems, end users should reach their local IT for support.
If you have TAC support, then you can escalate the issue to a TAC case, but that you need to do manually.
Just to clarify for future problems you might have.
java
if this helps, please rate
6 REPLIES 6
shh5455
Participant
Check the dial plan to see if the call is being allowed to route properly.
Dan Lukes
Advocate
Wrong forum. This forum is dedicated to feedback related to CSC framework itself. You can wish for more responses asking in the appropriate one.
Thank you Dan.
Cindy, I have moved this thread posted in "Feedbacks forum" to "IP Telephony" to get the answers.
Lavanya
CSC Moderator
Amit Sharawat
Hi Cindy,
Could you please provide the following details:
> Complete call flow: eg. PSTN---Voice gateway----CUCM---IP phone.
> What's the error, busy tone?
Based on above information i would ask you to collect some logs so that we track down the issue.
~Amit
Hello Amit,
I spoke with our IT department regarding this incident.  I am now told that it was not just my phone, but system wide.  The problem has since been resolved.
Please cancel this problem ticket.
Thank you,
Cindy
Jaime Valencia
java
Create
Recognize Your Peers
Content for Community-Ad
