i have a 8961 phone which doesn't start.
Only the upper both buttons are orange, screen is black, and the "navigation" kay is blinking some times.
I've tried the pressing # while "startup" and then 123456789*0# procedure but it doesn't work.
Does anyone knows how to reactivate the device?
Thanks a lot.
regards
Thorsten Könsgen
Hello Thorsten
Have you checked if the Phone receives enough power?
If possible try to boot the phone with a external power supply.
Best Regards
slashdots
Hello slashdots,
thank you for your reply.
The phone is connected to an external power supply. I've tried different power supplies (PWR-C-4).
So this does not to be the problem :-(
best regards
Thorsten
Same problem occured today. Powered over Ethernet. Spooky coincidence !
