09-12-2017 07:43 PM - edited 03-17-2019 11:09 AM
Hi Team ,
Phone is automatically connect with speaker when answering call , While dialing also automatically connect with speaker . I have done some investigation about this issue it seems hardware issue , Please advise what the cause and solution .
Solved! Go to Solution.
09-12-2017 09:26 PM
Pleas check if the Directory Number setting on CUCM for this phone is to set to 'Auto Answer with Speaker Phone'. If not, you may try deleting and readding the phone on cucm followed by a factory reset if the issue persists. If nothing works then you may need to check with a replacement phone.
Manish
- Do rate useful posts -
09-12-2017 09:26 PM
Manish
09-12-2017 09:49 PM
Thank you Manish , I will let you know update soon :)
09-13-2017 07:01 PM
Case solved - It seems hardware issue i think , Changed Loudspeaker option to disable after that phone handset reacted to accept calls .
Requested user is a manager so i cant investigate more , Can some one share what the cause behind on the issue :)
09-13-2017 08:14 PM
Good to know that, plz remember to mark the posts as answered when the issue is taken care of for the benefit of community users.
Manish
