phone background change
Vikram Prakash
i am trying to change the background image of CIPC but getting fail, as phone is not changing the background image.
i have used directory Desktops/320x212x16 and Desktops/320x212x12 both for same picture.
attached is for your referances.
list file configuration is as below
<CiscoIPPhoneImageList>
<ImageItem Image=”TFTP:Desktops/320x212x16/picture-thumb.png”
URL=”TFTP:Desktops/320x212x16/Screen_saver.png” />
</CiscoIPPhoneImageList>
Sasikumar Divvela
Is the image listing under CIPC user preferences->Background Images ?
Can you try with 320x212x12 image in XML.
You can refer to below article as well.
http://www.attanasio.be/james/?p=57
