11-04-2009 05:34 AM - edited 03-18-2019 10:47 AM
Hy
I have a DID with 1500 DN (4 digits), but not all is configured on CM 7.0
If I dial a DN unregistered in CM, phone not responding and blocks.
What is the problem?
Thanks.
11-04-2009 07:09 AM
Try to explain the problem in different words, because what you said cannot be really understood.
11-04-2009 08:41 AM
Sorry for my english.
I configured on CM 7.0 direcory numbers from 1000 to 2500, but not all directory numbers in this range it 's configured.
If I dial unconfigured directory number from the range above, the phone display freeze and if I press any key button the phone not responding for few minutes.
If I dial any number between 3000 and 9999, phone received the following reply : âcall cannot be completed .., please consult your directory number and call againâ .
Why the phone not receive this message : âcall cannot be completed .., please consult your directory number and call againâ, when I dial unconfigured directory number in the range 1000-2500?
Mention:
I have 2 CTI-RP configured with 1xxx and 2xxx
Thanks.
