Phone button template on CUCM 7.x
kevin.sullivan
I have created a new template and it is not showing up in the drop down when building a new device?
Chris Deren
is it for the correct device type?
Yes it is the same device type. It will show up in find and list phone button templates but when I go to build a new phone or change the phone button template it does not show up in the drop down list.
Chris Deren
how is your database replication looking?
Rob Huffman
Hi Kevin,
Can you please tell us the phone model you are trying to add a template for
and the exact CUCM version you are running??
Cheers!
Rob
