01-05-2013 10:40 PM - edited 03-16-2019 03:00 PM
I have a CME(2851+VIC2-4FXO),phone(cp-7906) calling num=7580 call PSTN by 4FXO (voice-port 0/0/3) ,An outgoing call later, prompt busy tone.
phone--cme--fxo--pstn
7580 0/0/3
config
voice translation-rule 3
rule 1 /^9/ //
rule 2 /^001/ //
voice translation-profile pstn-usa-out
translate called 3
R2851-US#sh voice port su
IN OUT
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
0/0/0 -- fxo-gs down down idle on-hook n
0/0/1 -- fxo-ls down down idle on-hook y
0/0/2 -- fxo-ls down down idle on-hook y
0/0/3 -- fxo-ls up dorm idle on-hook y
50/0/1 1 efxs up dorm on-hook idle y
50/0/1 2 efxs up dorm on-hook idle y
50/0/2 1 efxs up up on-hook idle y
50/0/2 2 efxs up up on-hook idle y
PWR FAILOVER PORT PSTN FAILOVER PORT
rule 1 /^9/ //
rule 2 /^001/ //
translate called 3
voice-port 0/0/3
translation-profile outgoing pstn-usa-out
pre-dial-delay 3
no battery-reversal
input gain 2
output attenuation -2
echo-cancel coverage 24
timeouts call-disconnect 120
timeouts ringing 5
timeouts wait-release 1
timing hookflash-out 50
timing guard-out 300
connection plar opx 7580
caller-id enable
dial-peer voice 4 pots
description ** FXO pots dial-peer **
destination-pattern 9[^0]T
direct-inward-dial
port 0/0/3
forward-digits all
supported-language BR dial-peer voice 4 pots
direct-inward-dial
port 0/0/3
forward-digits all
IN OUT
debug vpm signal
R2851-US#sh logg
Syslog logging: enabled (0 messages dropped, 3 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: level debugging, 195 messages logged, xml disabled,
filtering disabled
Monitor logging: level debugging, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 195 messages logged, xml disabled,
filtering disabled
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
Persistent logging: disabled
No active filter modules.
Trap logging: level informational, 97 message lines logged
Log Buffer (8192 bytes):
Jan 6 06:08:07.476: htsp_process_event: [50/0/1.1, EFXS_ONHOOK, E_DSP_SIG_1100]efxs_onhook_offhook htsp_setup_ind
Jan 6 06:08:07.476: [50/0/1.1] get_local_station_id calling num=7580 calling name= calling time=01/06 14:08 orig called=
Jan 6 06:08:07.492: htsp_process_event: [50/0/1.1, EFXS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]efxs_check_auto_call
Jan 6 06:08:08.776: htsp_digit_ready(50/0/1.1): digit = 9
Jan 6 06:08:08.976: htsp_digit_ready(50/0/1.1): digit = 1
Jan 6 06:08:09.176: htsp_digit_ready(50/0/1.1): digit = 3
Jan 6 06:08:09.376: htsp_digit_ready(50/0/1.1): digit = 4
Jan 6 06:08:09.576: htsp_digit_ready(50/0/1.1): digit = 7
Jan 6 06:08:09.776: htsp_digit_ready(50/0/1.1): digit = 8
Jan 6 06:08:09.976: htsp_digit_ready(50/0/1.1): digit = 5
Jan 6 06:08:10.176: htsp_digit_ready(50/0/1.1): digit = 6
Jan 6 06:08:10.376: htsp_digit_ready(50/0/1.1): digit = 8
Jan 6 06:08:10.576: htsp_digit_ready(50/0/1.1): digit = 9
Jan 6 06:08:10.776: htsp_digit_ready(50/0/1.1): digit = 5
Jan 6 06:08:10.976: htsp_digit_ready(50/0/1.1): digit = 7
Jan 6 06:08:11.176: htsp_digit_ready(50/0/1.1): digit = #
Jan 6 06:08:11.180: htsp_timer_stop3
Jan 6 06:08:11.180: htsp_process_event: [50/0/1.1, EFXS_OFFHOOK, E_HTSP_PROCEEDING]efxs_offhook_proceeding
Jan 6 06:08:11.180: [50/0/1.1] set signal state = 0x8 timestamp = 0htsp_setup_req
Jan 6 06:08:11.184: htsp_process_event: [0/0/3, FXOLS_ONHOOK, E_HTSP_SETUP_REQ]fxols_onhook_setup
Jan 6 06:08:11.184: [0/0/3] set signal state = 0xC timestamp = 0
Jan 6 06:08:11.184: htsp_timer - 1300 msec
Jan 6 06:08:11.436: htsp_process_event: [0/0/3, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_1100]fxols_power_denial_detected
Jan 6 06:08:11.436: htsp_timer2 - 1000 msec
Jan 6 06:08:11.436: htsp_timer_stop
Jan 6 06:08:12.436: htsp_process_event: [0/0/3, FXOLS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER2]fxols_power_den_disc
Jan 6 06:08:12.436: htsp_timer_stop
Jan 6 06:08:12.436: htsp_timer_stop2
Jan 6 06:08:12.436: [0/0/3] set signal state = 0x4 timestamp = 0
Jan 6 06:08:12.436: htsp_process_event: [0/0/3, FXOLS_ONHOOK, E_HTSP_RELEASE_REQ]fxols_onhook_release
Jan 6 06:08:15.536: htsp_process_event: [50/0/1.1, EFXS_OFFHOOK, E_DSP_SIG_0100]efxs_offhook_onhook
Jan 6 06:08:15.536: htsp_timer - 10 msec
Jan 6 06:08:15.548: htsp_process_event: [50/0/1.1, EFXS_OFFHOOK, E_HTSP_EVENT_TIMER]efxs_offhook_timer
Jan 6 06:08:15.548: htsp_process_event: [50/0/1.1, EFXS_ONHOOK, E_HTSP_RELEASE_REQ]efxs_onhook_release
Jan 6 06:08:15.548: htsp_timer_stop
Jan 6 06:08:15.548: [50/0/1.1] set signal state = 0x4 timestamp = 0
R2851-US#
01-06-2013 01:26 AM
Debug indicates phone line is not active.
01-06-2013 07:50 AM
indicates phone line is not active ?
This is what causes ?
01-06-2013 10:48 AM
When a Power Denial is detected, that means:
1-Cable is not connected
2-Far end FXS is not providing power anymore
Those 2 are the most common I've faced. You better contact your Telco to check the lines.
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
01-06-2013 06:37 PM
Hi all
Thank you !
1-Cable is not connected ?
FXO Cable is connected,
pstn call phone(7580) ,phone can Display telephone number,But answer Prompt busy tone!
2-Far end FXS is not providing power anymore?
this FXS port is cp-7906 phone , this phone Internal call is normal
config by CME
voice class dualtone-detect-params 1
freq-max-deviation 50
freq-max-power 20
freq-min-power 10
freq-power-twist 15
rule 1 /^9/ //
rule 2 /^001/ //
translate called 3
direct-inward-dial
port 0/0/3
forward-digits all
telephony-service
no auto-reg-ephone
em logout 0:0 0:0 0:0
max-ephones 35
max-dn 144
ip source-address 192.168.255.33 port 2000
auto assign 1 to 20
caller-id block code *916
calling-number initiator
timeouts busy 30
system message USA
url services
http://192.168.255.33/voiceview/common/login.do
url authentication
http://192.168.255.33/voiceview/authentication/authenticate.do
cnf-file location flash:
cnf-file perphone
user-locale 1 U1 load CME-locale-zh_CN-Chinese-8.6.2.4.tar
load 7906 SCCP11.8-5-4S.loads
load 7911 SCCP11.8-5-4S.loads
load 7960-7940 P00308000500.loads
load 7970 SCCP70.8-5-4S
load 7971 SCCP70.8-5-4S
time-zone 42
time-format 24
date-format yy-mm-dd
max-conferences 8 gain -6
hunt-group report url suffix 1 to 200
hunt-group report every 1 hours
moh music-on-hold.au
web admin system name public secret 5 $1$..eJ$PSx/owXWnMzTPchqWOEzn/
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
transfer-pattern 9.T
secondary-dialtone 9
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-template 1
network-locale 1
user-locale 1
codec g729r8 dspfarm-assist
ephone-dn 1 dual-line
number 7580
pickup-group 1
label TYQ
description 7580
ephone 11
no multicast-moh
device-security-mode none
mac-address 0021.D8BA.D678
ephone-template 1
codec g729r8
type 7906
button 1:1
01-07-2013 09:14 PM
Hi ALL
FXO-Cable is RJ11 or RJ21 ?
must need to Rj11 ?
