Phone Designer using CUCM 8.5 - Personalization is disabled on the selected device, HELP!
cinmachina
There is a thread where a gentlemen running CUCM 8.0.3 here: https://supportforums.cisco.com/message/3182594
He got it to work.
Basically I'm getting an error message that says "Personalization is disabled on the selected device" whenever I try to push or preview anything on the phone. I've enabled personalization on the phone, and have checked that the phones are associated to the end users. It still doesn't work.
This particular phone is a 7945 running SCCP45.9-1-1SR1S active load.
HELP!
There's a bug causing the problem that's fixed in 8.6(1):
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtk04412.  TAC can apply a fix if you open a case and reference this bug for you.
Neal haas
Level 3
Level 3
I could not get it to work either, I dont want to downgrade phones to a older version of the
Firmware. Readying posts over the last few weeks, it seems that quality control has gone by the way side at cisco.
Neal
Hello, I have the same Problem with a new CUCM 8.5 , I Have all 3 Personilzation Point Chacged to accept, but ist isnt allowed.
Joemar2,
I am running across the same issue and opened a support case with Cisco.  Here are the logs that prove this a part of the bug.
2011-09-01 09:30:20,116 INFO  [http-8443-22] servlet.PreviewBackground - doPost begins
2011-09-01 09:30:20,176 ERROR [http-8443-22] utils.CustomSSLProtocolSocketFactory - problem accessing trust storejava.io.IOException: stream does not represent a PKCS12 key store
java.security.KeyStoreException: problem accessing trust storejava.io.IOException: stream does not represent a PKCS12 key store
My question:
Cisco TAC hasn't informed me of a fix that they could apply.  Did you have a fix applied?  If so, do you have the TAC case I can reference to get this resolved?
