Phone Directory services
abdulkarim041
Level 2
Level 2
I have a Bluecom IP PABX. I am going to integrate it with CUCM. I want to bring directory numbers which are being used in Bluecom IP PABX to phones those will get registration to CUCM. How I can achieve it?
BR
AbdulKarim
Manish Gogna
Hi Abdul,
There is no direct/documented way to inherit or move the DN's from a third party PBX to CUCM. You will either need to do it manually ( if the number is small ) or use Bulk Administration Tool to achieve it. User related information can be inherited on cucm if your PBX was integrated with AD and the same AD is being integrated with cucm via LDAP.
Manish
Manish Gogna
Hi Abdul,
Manish
