phone model support on 11.5?
baselzind
Level 6
Level 6
i cant seem to find a document listing all the supported phone models on 11.5 , are these phones supported on 11.5 ?
7945
6945
6921
7911
6941
5 Replies 5
Jonathan Schulenberg
Except for the phone models listed in the release notes, every model will register.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/rel_notes/11_5_1/cucm_b_release-notes-cucm-imp-1151/cucm_b_release-notes-cucm-imp-1151_chapter_010.html#reference_769385C048EFD3322864E1C5CD86C355
Be be careful with your use of “support” though: if the endpoint model has reached End of SW Maintenance Cisco likely won’t fix a bug if one surfaces. The 6900 series phones reached that milestone in 2015.
https://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/unified-ip-phone-6900-series/eos-eol-notice-c51-730096.html
The 7905/7902/7912 phones are listed as deprecated phones on 11.5(X)
Also as per the field notice The registration on the phone will be blocked for the phone models in the Cisco Unified Communications Manager Release 11.5(x)
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/rel_notes/11_5_1/fieldNotice/cucm_b_fn-deprecated-phone-models-1151.html
Although I can see the phone model in Device defaults and also there is Add options in the CUCM 11.5.1.10000-6 version in my lab. screenshots are attached. I don't have 7905/7902/7912 phones to test.
One of my customer got these phone models and have a plan to upgrade from version 7.x.
Appreciate if any one can guide the latest available CUCM supported for 7905/7902/7912 phone models
11.0, but the problem is that 11.0 is no longer being developed and became EOL as soon as 12.0 was released. The long term release for 11.x is 11.5, they will need to plan how to replace those phones, as also 12.0 added some more devices to the list of deprecated endpoints.
java
if this helps, please rate
Jitender Bhandari
for any version of CUCM best way to check what phone model and features are natively supported is below.
Login to you CUCM on "Cisco Unified Reporting" -> System Reports -> Unified CM Phone Feature List Click on "Unified CM Phone Feature List" -> "Product:" select ALL, for "Feature:" select "All".
(Rate if it helps)
JB
Phone feature list, listed as Past End of Support for phones 7902/05/12 models. does that mean the phone cannot register
