Highlighted
Beginner
Phone not registered displayed on Cisco 6921 phone
V strange one, IP Phone is registered with CUCM 7.1.5 but on the Phone display its showing "Phone not registered". Even I can search using Corporate directory but once i get back on the main screen, same message appears on the phone.
Active load: 9.1.1
Thanks...
4 REPLIES 4
Highlighted
Beginner
- This issue may be related with custom Softkey template.
>> Search for a 6921 phone, select the default template and reset the phone. Now you can check again the registration status.
Highlighted
I'm getting the same notice, I've tried going back to default settings, removed the device a few times and it still shows that, only appears when first boot of the phone.
Running CUCM 8.5, had to manually do this Phone load:  SCCP69xx.8-5-3-0
As the 9.1 code would just sit there on the percentage screen at zero----you could still use the phone.  Even after letting the phone sit for 30 minutes it would still be at zero percent.
Other than that, not really a bad little phone.
Highlighted
Highlighted
What exactly is a default template and how do I find it?
one of our phones on a network was unplugged (computer and network) when it was plugged back in it says phone not registered and it will not change.
I reset the whole crappy comcast system and still nothing. All other phones working.
Content for Community-Ad
