Highlighted
Beginner
Phone not registering
Hello all. I'm working on my VOIP lab and running into a problem. This is my first attempt at VOIP so I'm really green.
I am running IOS: c3725-ipvoice-mz.124-25d.bin
I'm trying to use the 3725 as a TFTP server for the phones. I have DHCP set up on my asa with 150 pointing to the router. The phones get the appropriate IP address and see the router as the TFTP server.
I am trying to do this with SIP. My phone states that it is Unprovisied. Here is my configuration:
version 12.4
service config
hostname .......
boot-start-marker
boot-end-marker
enable secret 5 $1$pzMy$QYCtzB9IfLsBsE7Xm1aKr/
no aaa new-model
clock timezone Eastern -5
no network-clock-participate slot 1
ip cef
voice-card 1
no dspfarm
interface FastEthernet0/0
description To ASA
ip address 192.168.1.100 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http path flash:/gui
tftp-server flash:/phones/P0030801SR01.bin
control-plane
voice-port 1/0/0
voice-port 1/0/1
telephony-service
load 7960-7940 P0030801SR01
max-ephones 1
max-dn 1
ip source-address 192.168.1.100 port 2000
auto assign 1 to 1
create cnf-files version-stamp Jan 01 2002 00:00:00
max-conferences 8 gain -6
web admin system name ........ password .......
dn-webedit
time-webedit
transfer-system full-consult
ephone-dn  1  dual-line
number 9501
ephone  1
line con 0
line aux 0
line vty 0 4
password .......
login
ntp clock-period 17180322
ntp server 192.168.1.100
end
When I try to create the cnf files I get the following error:
%Error deleting flash:SEPDEFAULT.cnf (File not found)
%Error deleting flash:XMLDefault.cnf.xml (File not found)CNF-FILES: Clock is not set or synchronized,
                retaining old versionStamps
I need a nudge in the right direction. I would like to at least assign the phone a number and get moving towards it recognizing the router and receving the appropriate configuration.
Any help would be greately appreciated!
Everyone's tags (2)
4 REPLIES 4
Beginner
Adam,
I don't see the MAC address added to ephone 1, have you tried adding the MAC?
Rising star
Re: Phone not registering
Look at this for a basic setup of CME.
http://www.ciscopress.com/articles/article.asp?p=1182471&seqNum=2
Some parts of the guide are not really necessary, like the part were the allow-connections commands are used. The SCCP CME phones are seen as virtual POTS ports (FXS in this case) to the router, so it wouldn't be VOIP to VOIP, and that's what the allow commands allow you to have. For normal POTS to VOIP there are no need to use any allow commands.
You also mentioned that you were trying to set the phones up for SIP, but your CME config are for SCCP. I would recommend you to stick with SCCP, the CME implementation for SIP is really clunky and not as easy to setup as it's more evolved SCCP counterpart.
Please rate all useful posts.
Please remember to rate helpful responses and identify helpful or correct answers.
Beginner
I've put some more work into this today. I do seem to have a SCCP image but the phone I have is stuck on SIP. I am trying to get it to convert over. I have P0030801SR01.bin / .loads / .sb2 .sbn all in flash:/phones
I have SEP.cnf.xml, SIP.cnf, SIP.cnf.xml, and OS78XX.txt all in flash:
The phone doesn't seem to want to switch over from SIP to SCCP. I've updated the configuration now to:
version 12.4
service config
service password-encryption
hostname Exarch3725
boot-start-marker
boot system flash
boot-end-marker
no aaa new-model
clock timezone EST -5
ip cef
voice-card 1
no dspfarm
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
sip
  registrar server expires max 600 min 60
username FerrelEx privilege 15 password 7 122E0A1B1418051C7C6D62
description To ASA
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
ip http server
tftp-server flash:SIPDefault.cnf
tftp-server flash:OS79XX.txt
tftp-server flash:SEP0002FD659E85.cnf.xml
tftp-server flash:SIP0002FD659E85.cnf
tftp-server flash:SIP0002FD659E85.cnf.xml
tftp-server system:/its/XMLDefault7960.cnf.xml alias SEP0002FD659E85.cnf.xml
control-plane
voice-port 1/0/0
voice-port 1/0/1
telephony-service
max-ephones 10
max-dn 10
auto assign 1 to 1
create cnf-files version-stamp 7960 Sep 22 2012 23:19:23
web admin system name FerrelEx secret 5 $1$mr8D$jw3hRNnoMTHDMpb3yvDUr/
number 9501
name Adams Desk
ephone  1
mac-address 0002.FD65.9E85
type 7960
button  1:1
line con 0
line aux 0
line vty 0 4
password 7 02310B570D1506391A084F
login
ntp master
end
The phone now seems to continually reset and I am still getting the same error as before.
Rising star
Converting a phone from SIP to SCCP, or vice versa, with CME can be a very painful process.You can do a debug tftp events to see the request of the different files during phone boot sequence. From this you might be able to figure out where it goes wrong.
But a much easier way to convert the phone is to temporary point it to boot from a CUCM. After it has downloaded the firmware you can again point it to CME. If you use this method you should remove the load statements.
Content for Community-Ad
July's Community Spotlight Awards
