195
Highlighted
Beginner
phone number too long?
I've  the following problem.
I'm trying a phone number of 23 digits.
The callmanager send correctly all digits to voice-ge, but the voice-ge send to PSTN only the first 20 digits.
The callmanager io 4.2.3 and the voice-gw in a 3745 with IOS c3745-ipvoicek9-mz.124-15.T13.
giancarlo
2 REPLIES 2
Highlighted
Hall of Fame Cisco Employee
What's your GW config?
MGCP? H323? SIP
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Highlighted
my voice-gw is H323 and this is the config
network-clock-participate slot 1
network-clock-participate slot 2
no network-clock-participate slot 4
network-clock-select 1 E1 1/0
voice-card 1
no dspfarm
voice-card 2
dspfarm
voice-card 4
dspfarm
dsp services dspfarm
ip cef
no ip domain lookup
isdn switch-type primary-net5
voice call send-alert
voice call convert-discpi-to-prog
voice call carrier capacity active
voice service voip
h323
modem passthrough nse codec g711alaw
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
voice class h323 1
h225 timeout tcp establish 3
voice translation-rule 1
rule 2 /^0/ /00/ type unknown unknown
rule 3 /^3/ /03/ type unknown unknown
rule 4 // /00/ type national national
rule 5 // /000/ type international international
voice translation-profile ENTRANTI
translate calling 1
sccp local FastEthernet0/0
sccp
sccp ccm 10.133.3.22 priority 1
sccp ccm 10.133.3.23 priority 2
sccp switchback timeout guard 180
dspfarm transcoder maximum sessions 6
dspfarm confbridge maximum sessions 6
dspfarm rtp timeout 60
dspfarm connection interval 60
dspfarm
dial-peer cor custom
