01-24-2011 04:16 PM - edited 03-16-2019 03:03 AM
When installing the Call Manager Certs on the ASA do you install the CAPF-trust or CallManager-trust certificates to use the Phone provy feature. For example, there are two sets of CAP-RTP-001.pem so which one do you download in install?? Thanks!
01-25-2011 01:04 AM
If you want to authenticate the phone using Manaufacturer Installed Certificate, you have to download Cisco_Manufacturing_CA.pem.
If you want to Authenicate IP phones with a LSC (Local significant Certificate), you have to download the CAPF cetificate.
01-25-2011 06:37 AM
Yes, I understand that but here are two Cisco_Manufacturing_CA.pem certificates one is associted to CAPF-trust and one is associated to CallManager-trust.
So which one should I use?? Every Cert has to associations...CAPF-trust and CallManager-trust.
*CAP-RTP-001
*CAP-RTP-002
Thanks!!
02-21-2011 04:22 PM
Doesn't matter. They're both the same. CUCM has different trust stores for different features.
Best regards,
-Justin
