phone-proxy phone not registering with call manager
fasteddye
We have a working phone-proxy setup.  However, there is one phone that is not registering with call manger from phone-proxy.  This phone registered fine on internal network and with our test DSL at office.  When taken out to site, the phone is not registering.  The CTL file was removed.
The show phone-proxy secure-phones command shows this phone connected but Port = 0
Interface      IP Address  Port MAC            Timeout Idle
  outside    184.xx.xx.xx     0  00ab.cdef.higk 0:05:00 0:01:22
This phone does not show up in the show phone-proxy signaling-sessions command.
I am having trouble figuring out what may be causing this phone to not register with Call Manager since it registered fine on internal network and test DSL connection at office but not at site.
All other phones on phone-proxy are working ok.
Thanks.
5 Replies 5
thisisshanky
Level 11
Level 11
not the expert in asa configs..but usually using a packet tracer in the asa (available in cli and asdm) might help identify whats happenign with the specific traffic...
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Real-time traffic is consistently showing the Teardown and Built inbound UDP connections
There is no other traffic for the 184.XX.XX.XX (IP Address the phone is coming from).
We have a number of other phone-proxy phones working ok.
6  Jun 22 2011     08:24:45               184.XX.XX.XX     12995    10.XX.XX.XX       47270    Built inbound UDP connection 351536929 for outside:184.XX.XX.XX/12995 (184.XX.XX.XX/12995) to inside:10.XX.XX.XX/47270 (64. XX.XX.XX /47270)
6  Jun 22 2011     08:24:45               184.XX.XX.XX     12995    10.XX.XX.XX       69           Built inbound UDP connection 351536928 for outside:184.XX.XX.XX/12995 (184.XX.XX.XX/12995) to inside:10. XX.XX.XX /69 (64. XX.XX.XX /69)
6  Jun 22 2011     08:24:43               184.XX.XX.XX     12989    10.XX.XX.XX       48508    Teardown UDP connection 351522359 for outside:184.XX.XX.XX/12989 to inside:10.XX.XX.XX/48508 duration 0:02:01 bytes 516
6  Jun 22 2011     08:24:43               184.XX.XX.XX     12989    10.XX.XX.XX       69           Teardown UDP connection 351522358 for outside:184.XX.XX.XX/12989 to inside:10.XX.XX.XX/69 duration 0:02:01 bytes 0
Thanks.
Ended up being the DSL modem mode.  As a last resort, we called the DSL provider just see if there was any packets being dropped or ports blocked.  They let us know that the modem by default was in routed mode meaning that it is basically blocked all ports.  They assisted us in switching the DSL modem into bridged mode and the phone registered immediately.
st
excuse me i am configure phone proxy but that doesn't work if you possible please send me your configuration in asa and your topology please help me
I used the following links for assistance setting up our phone proxy.
https://supportforums.cisco.com/docs/DOC-1364
http://angryciscoguy.com/jello/?p=100
Hope that helps.
