02-23-2017 01:46 PM - edited 03-17-2019 09:37 AM
I have the latest CME on a 2911 router with 7975 phones running SCCP. I'm trying out the new 8861 SIP phone but it keeps going offline and registering. As well, I can place a call but it disconnects the call after about a minute. I don't have this problem at all with the Skinny phones so there must be a config that is not setup right.
What's the config I should have for an 8861 phone and any other global settings? Or in general, what's the config I should have for a sip phone. If anyone has SIP phone working on CME and can share their parts of the config that should work I would appreciate that.
Thanks.
02-23-2017 07:34 PM
Please verify the config as per following
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-express/99946-cme-sip-guide.html#configs
Manish
02-23-2017 07:44 PM
Okay will look at that but...
What is the password so I can get into the Admin on the 8861 phone? I want to be able to set the voice VLAN and the Data VLAN like the Skinny 7975's. Right now it's picking up the data vlan so maybe that's the problem.
Second, how do I configure multiple extensions on this phone? With Skinny it was easy to me. I could do something like: button 1:49 3o40,36 6:33 7:2
Right now I have one extension on the 8861 but I want to be able to see/select several extensions.
I don't see this in the literature. Can you write out how to do this? Thx.
