phone reset options and SSL VPN cert survivability
tato386
Level 6
Level 6
I have CUCM self-signed (CAPF I believe) certs on my 7900 and 8800 series phones that are used to establish AnyConnect SSL VPN.  If I have a problem with a remote phone I want to make sure that I don't delete this cert.  What reset options can I use that _wont_ delete the cert?  In the unfortunate event that a cert is deleted, is there a way to install the cert and VPN config on a phone that is not able to establish a VPN?
Hi DIEGO,
Reset Security Settings and performing factory reset will delete the
certificate.
If you lose it, you need to get the phone back to put the certificate.
Hi DIEGO,
certificate.
Hello Mohammed,
Got it.
Diego
