Phone sending multiple SIP registrar request to ISP unwantedly
Jayesh05051988
Following is the message from SIP ISP.
A single registration coming multiple times is not an issue and is actually expected under certain circumstances.  What I am seeing through is between 130 and 150 simultaneous registrations active with us from your WAN IP of 205.XXX.XX.XX when you should have a grand total of 2 between the two online trunking devices on the account.
Can anyone tell why CME is sending such request.
Thanks in advance
Jayesh
When you configure your DNs make sure that you use the keyword no-reg with the number command. This will avoid the DNs to register with registrar server such as ISP.
