Phone Subscriber questions
Kent Drugge
CUCM, CUC, IMP 11.5  Pub, Sub1, Sub2  Good Day, How do I see which subscriber a phone is connected to ?  Can I make it change subscribers ?  Thanks,
Jaime Valencia
Device -> phone and you'll see where the devices are registered to
Yes, you can perform config changes in the subscriber.
java
if this helps, please rate
Jaime Valencia
java
Thank you Jamie, I was going one step too far and clicked on the device out of habit. Isn't is possible to change the subscriber, similar to changing presence users ?  I thought I did it once before, or tried to at least. Thanks,
You affect which Subscriber the phone registers to by changing the Phone's Device Pool's Communications Manager Group.
