09-23-2015 06:02 AM - edited 03-17-2019 04:22 AM
Hi every body , i hope all on a good conditions, strange problem happened to me is that i have Cisco IP phones ( CP-7841-K9 ) i tried to add them but i couldnt found them on phone type field
any one faced this problem before.
thanks and appreciate help on that issue
refer the attached file to understand.
09-23-2015 06:10 AM
Make sure the cucm is one of the following
8.5.1
09-23-2015 07:50 AM
09-23-2015 08:20 AM
As Manish and Rob said, you will need to install the proper device pack to support 7800 series IP Phones, you can check it out here:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/compat/matrix/CMDP_BK_CCBDA741_00_cucm-device-package-compatibility-matrix.pdf
Or here:
http://www.cisco.com/web/software/282074299/107528/cmterm-devicepack-8.6.2.24104-1_Readme.pdf
After installing the device pack you have to reboot all the CUCM servers in your cluster.
09-23-2015 06:12 AM
Hi there,
If the 7841 is not supported/shown as an available device type on your current CUCM version you will need to install the appropriate Device Pack and reboot all servers in the cluster. If you let us know what version of CUCM you are running we can point you in the right direction for what Device package to install.
Cheers!
Rob
09-23-2015 07:39 AM
09-23-2015 07:38 AM
the version is 8.6
the version is 8.6
