11-17-2012 09:20 AM - edited 03-16-2019 02:14 PM
Hi All
I have a major problem at a suctomer site. I attended just to reset the password on their 2801 CME router. After reseting the password the phones will not come up, I've incuded as much detail as possible here as I am really up against it for time. Any help would be hugely appreciated.
Equipment:
2801 Router with CME
2950 switch
6 7940 phones
1 7970 phone
They do have another switch and router on site but this is independant as far as I can see. Phones are patched directly to the 2950 switch.
Here's what happened
booted into rommon and changed the config register to 2142 and restarted
viewed the startup config and copied into a text file
copied the startup config to running config
change enabled secret
copied running config to startup config
rebooted
Phones didn't come up. Logged into router, could see fe0/0 and subinterfaces as well as the tftp service engine were admin down. Brought them up. Eventually all phones come back up.
Because they were admin down, I was worried that if they had a power cut, the same thing would happen and the phones wouldn't come up. So I rebooted again to see if the same thing would happen, which it did. This time though when I brought the interfaces up the phones didn't come back up except for the 7970. I rebooted the switch, no effect.
When the phones boot it says 'no load specified' and then configuring vlan, then goes to configuring ip and just sits there. Sometimes some phones will get the correct DHCP information (g/w, tftp, cme rotuer) but still sit on configuring IP.
I've tried putting settings in manually - same thing
If I do a show ip dhcp bindings I can see the phones have been given leases but they don't show on the phone.
Config Summary
Phone VLAN: 700
Interface: fe0/0.700
IP: 192.168.80.253 (I can't ping this from the my laptop but I guess I shouldn't as I wont be on the phone vlan?? although I have set myself an address on that range)
The DHCP config looks ok apart from the following which I have never seen.
no ip dhcp use vrf connected
I'm not very experiences at all in VOIP and I don't know how to move forward.
debug TFTP and DHCP events show nothing. I have not reset the password on the switch, I feel the problem is on the router as the sytem usually recovers from power outages, and also worked today.
Thanks all. I'm really up against it.
Solved! Go to Solution.
11-17-2012 12:10 PM
Hi.
Try , under telephony-service, to put create cnf-files command.
For warning message shut and no shut for these interfaces
interface BRI0/0/0
interface BRI0/0/1
Carlo
11-17-2012 10:27 AM
Hi Paul.
Can you attach the actual config of vg and a couple of show:
show ip int brie
show ip dhcp binding.
Also remember to reset the configuration register to 0x2102. If you reboot the router without changing this value, the router will alway ignore the startup config.
Carlo
11-17-2012 10:45 AM
Hi Carlo
Yes I reset the config register, back to 2101 though not 2102??
Show IP DHCP Binding
192.168.80.5 0100.1bd4.3387.4a Nov 18 2012 06:44 PM Automatic
192.168.80.7 0100.1bd4.6045.5a Nov 18 2012 06:44 PM Automatic
192.168.80.9 0100.1bd4.6048.ec Nov 18 2012 06:44 PM Automatic
192.168.80.10 0100.1bd4.604a.c4 Nov 18 2012 06:44 PM Automatic
192.168.80.11 0100.1bd4.6067.84 Nov 18 2012 06:44 PM Automatic
192.168.80.12 0100.1bd4.604b.4f Nov 18 2012 06:44 PM Automatic
192.168.80.13 0100.070e.1653.53 Nov 18 2012 02:51 PM Automatic
Trying to figure how to attach the config... :-)
pride-cme-cov_01#show ephone summary
hairpin_block:
ephone-1 Mac:0007.0E16.5353 TCP socket:[1] activeLine:0 REGISTERED
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 debug:1
IP:192.168.80.13 7971 keepalive 466 1:1 2s101
sp1:902476450871
ephone-2 Mac:001B.D460.4C12 TCP socket:[-1] activeLine:0 UNREGISTERED
IP:0.0.0.0 Unknown 0 keepalive 0
ephone-3 Mac:001B.D460.4AC4 TCP socket:[-1] activeLine:0 UNREGISTERED
I've ommitted identical ephone entries
FastEthernet0/0 unassigned YES NVRAM up up
FastEthernet0/0.2 172.25.70.254 YES NVRAM up up
FastEthernet0/0.100 192.168.1.254 YES NVRAM up up
FastEthernet0/0.700 192.168.80.253 YES NVRAM up up
Service-Engine0/0 192.168.80.253 YES TFTP up up
FastEthernet0/1 unassigned YES NVRAM administratively down down
BRI0/0/0 unassigned YES NVRAM up up
BRI0/0/0:1 unassigned YES unset down down
BRI0/0/0:2 unassigned YES unset down down
BRI0/0/1 unassigned YES NVRAM up up
BRI0/0/1:1 unassigned YES unset down down
BRI0/0/1:2 unassigned YES unset down down
BRI0/1/0 unassigned YES NVRAM administratively down down
BRI0/1/0:1 unassigned YES unset administratively down down
BRI0/1/0:2 unassigned YES unset administratively down down
BRI0/1/1 unassigned YES NVRAM up up
BRI0/1/1:1 unassigned YES unset down down
BRI0/1/1:2 unassigned YES unset down down
BRI0/3/0 unassigned YES NVRAM administratively down down
BRI0/3/0:1 unassigned YES unset administratively down down
BRI0/3/0:2 unassigned YES unset administratively down down
NVI0 unassigned NO unset up up
Dialer3 172.31.1.193 YES NVRAM up up
Dialer255 10.10.10.1 YES NVRAM up up
As I say, the fastethernet 0/0 and serviceengine interfaces are administratively down when I restart
11-17-2012 11:27 AM
Hi.
As I can see, IP phones are taking ip address from the dhcp.
Try a clear ip dhcp binding * and power cycle a 7940.
See if it brings the ip address.
Wich behaviour do you see on unregistered ip phones?
Let me know
Carlo
11-17-2012 11:36 AM
Hi Carlo
I'm remote at the moment so cannot power cycle the phone. I would have done that many times I think during various reboots. I know for sure I cleared the dhcp binding and restart the switch, I would then have restarted the a few of the phones.
I'm curious as to why the interfaces are always down after a reboot? Earlier when I restarted the router I would get a message on the phones "configuring cnf" not sure about the 'f'. It would alernate between that and the configuring IP. now the phones sit on configuring IP.
Did the config look ok? I can't understand it, nothing has changed apart from that password.
Maybe I should try wiping the config and pasting the original config back in? Would it be safe to do it in that way? I don't want to setup a tftp server if I don't need to
*** Slight update to original situation
I have reload the router, this time not even the 7480 is registered.
Another thing intersting to now maybe... I get this message on restart just before the prompt is available.
Warning: Interface must be cleared after reconfiguring the TEI.
11-17-2012 12:10 PM
Hi.
interface BRI0/0/0
interface BRI0/0/1
Carlo
11-17-2012 12:44 PM
Thanks Carlo we have progress! I could kiss you! sorry... It seems that now we have 6 phones registered, looks like the 7940's, only 1 missing, ephone 1. I have restarted it using the reset MAC-ADDR
Creating CNF files
CNF-FILES: Clock is not set or synchronized, retaining old versionStamps
ephone-1 Mac:0007.0E16.5353 TCP socket:[-1] activeLine:0 UNREGISTERED
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:0
IP:0.0.0.0 0 Unknown 0 keepalive 0 max_line 0
Username: Mahomed Password: 12345
Username: Test
ephone-3 Mac:001B.D460.4AC4 TCP socket:[4] activeLine:0 REGISTERED in SCCP ver 6 and Server in ver 5
mediaActive:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:7
IP:192.168.80.2 51208 Telecaster 7940 keepalive 6 max_line 2
button 1: dn 3 number 2003 CH1 IDLE CH2 IDLE
button 2: dn 101 number 2501 cfa 2003 CH1 IDLE CH2 IDLE overlay shared
overlay 2: 101(2501) 102(2502) 103(2503) 104(2504) 105(2505) 106(2506)
Username: Tina
ephone-4 Mac:001B.D460.48EC TCP socket:[2] activeLine:0 REGISTERED in SCCP ver 6 and Server in ver 5
IP:192.168.80.4 51913 Telecaster 7940 keepalive 8 max_line 2
button 1: dn 4 number 2004 CH1 IDLE CH2 IDLE
ephone-5 Mac:001B.D433.874A TCP socket:[6] activeLine:0 REGISTERED in SCCP ver 6 and Server in ver 5
IP:192.168.80.5 51513 Telecaster 7940 keepalive 8 max_line 2
button 1: dn 5 number 2005 CH1 IDLE CH2 IDLE
ephone-6 Mac:001B.D460.4B4F TCP socket:[5] activeLine:0 REGISTERED in SCCP ver 6 and Server in ver 5
IP:192.168.80.1 49795 Telecaster 7940 keepalive 8 max_line 2
button 1: dn 6 number 2006 CH1 IDLE CH2 IDLE
ephone-7 Mac:001B.D460.455A TCP socket:[1] activeLine:0 REGISTERED in SCCP ver 6 and Server in ver 5
IP:192.168.80.7 51344 Telecaster 7940 keepalive 9 max_line 2
button 1: dn 7 number 2007 CH1 IDLE CH2 IDLE
ephone-8 Mac:001B.D460.6784 TCP socket:[3] activeLine:0 REGISTERED in SCCP ver 6 and Server in ver 5
IP:192.168.80.3 51865 Telecaster 7940 keepalive 9 max_line 2
button 1: dn 8 number 2008 CH1 IDLE CH2 IDLE
Thank you so much!
11-17-2012 12:53 PM
Sorry I'm married
Glad to help you.
Please rate helpful post and, in case you consider that your question in answered, please mark it as answered.
regards
Carlo
11-17-2012 01:10 PM
haha.
Do you have any ideas for the remaining phone, e-phone 1, a 7970.
If I do show ip arp the mac is not listed or in DHCP bindings.
I will definatley rate your post, can I put correct answer on multiple posts, just wondering if I should wait untill all phones are working.
I am definatley not reseting this time. I also do not want to reset the dhcp pool encase they don't get an address again :-)
11-17-2012 01:51 PM
Go to the switch and shut the port where 7970 is connected to.
On the router, clear ip dhcp binding 192.168.80.13 and no shut on the same port.
Bye
Carlo
11-17-2012 01:58 PM
unfortunatley I have no access to the switch. I will have to re-connect manually tomorrow, hopefully it will come up. Funny how its either one type of phone or the other that works most of the time.
I will update tomorrow.
pride-cme-cov_01#clear ip dhcp binding 192.168.80.13
% Adddress 192.168.80.13 is not in the database.
11-17-2012 02:06 PM
I saw that 7970 had that ip address.
In this case... show ip dhcp binding and clear ip dhcp bind of 7970 assigned ip.
Carlo
11-17-2012 04:02 PM
The 7970 no longer has a DHCP binding. MAC address is 0007.0E16.5353
pride-cme-cov_01#show ip dhcp bind
Bindings from all pools not associated with VRF:
IP address Client-ID/ Lease expiration Type
Hardware address/
User name
192.168.80.1 0100.1bd4.604b.4f Nov 18 2012 08:33 PM Automatic
192.168.80.2 0100.1bd4.604a.c4 Nov 18 2012 08:33 PM Automatic
192.168.80.3 0100.1bd4.6067.84 Nov 18 2012 08:33 PM Automatic
192.168.80.4 0100.1bd4.6048.ec Nov 18 2012 08:33 PM Automatic
192.168.80.5 0100.1bd4.3387.4a Nov 18 2012 08:33 PM Automatic
192.168.80.7 0100.1bd4.6045.5a Nov 18 2012 08:32 PM Automatic
Maybe I need to rebuild cnf for that phone? I assume the phone keeps trying to get an IP if doesn't have one. I'm hoping a power cycle on the phone will do but I'm not confident. I will going to site in the morning, if you can reccomend anything esle to try if power cycle doesn't fix it would be very much appreciated. So stange that this was the only one that worked at one stage.
I cannot thank you enough.
11-18-2012 05:38 AM
Hi Carlo
Thanks so much, a power cycle on that remaining phone done the job. I'm a little converned about the interfaces being admin down on but never mind.
Thanks.
