Phones register to SRST but DNs do not get Extensions
Devavrat Oka
I have the following deployment:
CUCMBE 8.5, CCM-Manager 7.1, 2921 voice gateway (IOS c2900-universalk9-mz.SPA.150-1.M4.bin), Phone load SCCP45.8-5-4S
All phones register to CUCMBE just fine but when I test my SRST gateway, the phones do register but the extensions do not associate with a DN. Its a pretty common problem but I made sure all the versions and loads and IOS are compatible for this feature. I have no clue why my phones do not get a DN when they fallback to SRST. Here're the necessary configs:
<<output omitted>>
ccm-manager fallback-mgcp
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.97.22.252
ccm-manager config
mgcp
mgcp call-agent 10.97.22.252 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
mgcp profile default
<<output omitted>>
gatekeeper
shutdown
call-manager-fallback
secondary-dialtone 8
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 10.97.22.254 port 2000
max-ephones 100
max-dn 150
system message primary CallManager Unavailable
dialplan-pattern 1 8[2-9]......... extension-length 10
keepalive 10
time-zone 5
Does anyone know what could be a workaround for this? I am considering going ahead with the 15.0(1)XA IOS for my 2921 voice gateway. I will post an update on what I observe after the IOS upgrade.
Thanks for taking some time out and looking at this. Appreciate all the help and assistance.
5 Replies 5
Jason Polce
Level 4
Level 4
I have run into this issue before and it has to do with the phone loads and SRST version. It was a conflict with the button template. I was running 7.1 on the router and needed to use 8.4.1 to get it going correctly. I think for CME 8.5 the recommended phone load is 9.1.
- Jason
Downgrading the Phone-Load to SCCP45.8-3-3SR2S worked for me. I always knew it was a Phone-Load issue after looking at similar discussions on the Internet. I tried 8.5.4. and 8.4 and 9.1 and 9.0, it was just a matter of finding the right load. Thanks Jason!
I agree with others here, it's typically a phone load or IOS compatibility.
Chris
Geez now my phone-load is legacy and won't sow the correct time. Instead of using the local NTP time from the voice gateway, it shows the UTC time.
Ok it was an issue with the legacy phone-load. Phone-Loads 9.0(2) and prior require you to select a compatible time zone (marked with 2 '+' signs one on top of other) on the Call Manager NTP reference list.
