09-18-2016 12:50 PM - edited 03-17-2019 08:07 AM
Good Afternoon,
I am having issues with SIP phones resetting every few minutes. I can't remember exactly what caused it last time but it had something to do with the
I
09-19-2016 01:30 AM
If the phones and DHCP server are in different subnet, then you need to use "ip helper-address" Command.
http://www.ciscopress.com/articles/article.asp?p=330807&seqNum=9
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipaddr_dhcp/configuration/12-4t/dhcp-12-4t-book/config-dhcp-relay-agent.html
Rajan
09-19-2016 07:17 AM
Fixed it with the bind command.
voice service
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface GigabitEthernet0/0
bind media source-interface GigabitEthernet0/0
registrar server
09-19-2016 06:16 AM
It seems that you have intermittent connectivity drops between remote lan and CME which is causing the phones to reset.
I think you need to troubleshoot the connectivity.
