I'm trying to get two Cisco IPC phones to register with a CUCM that I've set up in a lab environment in preparation for CCNA Voice. Attached is a screenshot of the wireshark output when one of the phones attempts to register with the server. There are two things I find very odd, but haven't been able to figure out. 1) The phone can't find SEP08002782FA2F.cnf.xml. I've configured the phone and I have no idea why the server is responding with a 404. I've attached a screenshot of my phone config page. 2) The TFTP port (69) is not open even though the TFTP service is running.
I'm really not sure what I'm doing wrong. The only status messages on the phone are:
File not found: SEP08002782FA2F.cnf.xml
CTL update failed
XMLDefault.cnf.xml
The CUCM's server name is cucm and I've confirmed the name resolves appropriately to 192.168.1.15.
Thanks for your time. Any help appreciated.
Grant
Solved! Go to Solution.
Quick point to check with... include SEP in device name viz SEP08002782FA2F (instead of 08002782FA2F).
Vivek
Vivek
That was it! Well that's rather obnoxious. CME added the SEP automatically; I didn't even think to add it in the name on CUCM. Thanks so much for your answer.
What made that even more confusing now that I look, is that on CBT Nuggets he doesn't add SEP to the front... because his says MAC Address instead of device name O.o
Glad to know its worked for you.
Vivek
