AMA-CUCM Troubleshooting: Best Practices for Reading Trace Files
4669
Beginner
Hey, I add in AD a user and
Hey,
I add in AD a user and log in to web access with the user.id and it works, after I go to User setting to change the default pin I receive the message the Default PIN is wrong:(
I do not understand  what I am doing wrong :(((((
Engager
HiAre you sure that you check
Are you sure that you check change in next login , please check.
please rate all useful information
Beginner
I test only  with Does Not
Now I left only User Must Change at Next Login ENABLED and I change the pin to 1234. I will wait 5 minutes and i will log in to web access to see if it's work.
Th
Highlighted
Beginner
HI,I find a fix up for this
HI,
I find a fix up for this.If I go to Bulk Administration/ Users/Reset Password/PIN/Query and find the user.id and Enabled User Must Change at Next Login and write a PIN and Run Immediately. After the Job is done every user have to go Web access and change the PIN and then can go to Personal Directory on the Phone and type the new PIN.
Engager
+5 for you , i know this
+5 for you , i know this solution but i think it only used when we used BAT tool will be ok with LDAP integration but i was going to advise you about. Anyway i am so happy that you fix your problem.
Beginner
Thanks a lot for help :)
Engager
Thank so much for your
Thank so much for your patience and have a nice day. many thanks that you share your final solution which hit the issue.
thanks
Engager
Hi Just keep this url as
Just keep this url as reference
https://supportforums.cisco.com/discussion/11516276/extension-mobility-disable-change-pin
thanks
please rate all useful infromation
Engager
HelloJust after you did
Hello
Just after you did change on credential policy . Just do one thing to make sure , just add a new user on AD and do resync , and check if he can able to login again or not.If the policy applied and this will be 100% , so we will disable LDAP and we apply it again ,if the test failed so keep your LDAP running.
Content for Community-Ad
August's Community Spotlight Awards
