02-02-2017 01:14 PM - edited 03-17-2019 09:24 AM
I need to set up Plar for an ata186 to use. The actual configuration for Plar is all good and I've tested against an SIP phone it rings on lifting the handset to the correct destination. But if I assign the same css against the ata186, I just get dial tone, I can ring out on it by assigning a different css but if I reassign the Plar css I just get dial tone.
Config
Pt_plar
Css_plar
Pt_plar
TP ' ' - blank
Partition PT_plar
Mask - destination DN ' '
Css_internal
Css_plar assigned the ata186
It fails, just dial tone if I apply the above css to a phone it works as designed but assign the same Css_plar, the Ata provides dial tone when lifting the handset
If I change blank TP DN to another number such as a single digit say 1 again it works but change it back to blank, dial tone only - should it work?
Wayne
02-02-2017 01:34 PM
And what protocol are you using for that ATA?
02-02-2017 01:37 PM
Not sure as I'm away from ccm. Is there a difference between sccp or SIP and how it works?
I can always change protocol
02-03-2017 01:23 PM
I wasn't able to set up an ATA186 as SIP (on 9.1.2) so SCCP was my only option. I don't know if an ATA supports SIP in later CUCM versions.
This is how I do SCCP PLARs:
1. Create a partition specifically for the PLAR.
2. Create a CSS with the partition in step 1 as the only member.
3. Configure a translation pattern where the pattern is empty, the partition is the one you created in step 1. I use a simple CSS that contains some of my internal partitions. In the called party transformations, enter the destination DN in either the called party transform mask or prefix digits (outgoing calls). Either one seems to work for me. I only use internal DNs; I haven't tried with external numbers.
4. Add your ATA186 if it isn't already in your database. I use a standard device pool and calling search space on the base device.
5. Add a DN to the ATA and select the partition you created in step 1. The line CSS is the one you created in step 2.
When I had this problem, I usually either missed assigning the DN to the PLAR partition or the line CSS was wrong. When I corrected the partition and line CSS, it started working.
SIP PLARs require some extra steps which has to be done in SIP dial rules. I found some good documentation doing a Google search for SIP PLAR.
I hope that helps.
Bill
