Play Azan Through IP Phones
abdul rasheed
Hi All
I am from Saudi Arabia. Is there anyway to play azan (timely alarm to notify prayer time) through IP phones? I am using CUCM 9.1 in my HQ and Standalone CME in Branches. Please respond ASAP.
Thank You
Abdul Rasheed
7 Replies 7
Jaime Valencia
CUCM doesn't provide any of that, you would need to use something like Informacast in order to send the paging message, or build your own.
java
if this helps, please rate
Hi Jaime
Thank you for your response. What do you mean by build your own? Create XML service?
Thank You
Abdul Rasheed
We've configured that a lot of times for our customers here in SA, 3rd party applications do multicast audio at the time of the Azan. Nevotek has a good experience on that.
Thank you,
Shadi
Hi Dear,
I have also Scheduling and Playing Azaan requirement in KSA.
Customer is using only CME 2951 with IOS 15.1(4)M3
It is necessary to have third party application?
Secondly, can you please provide the configuration sample, if it is really possible through CME.
Appreciate your help.
Mohsin Majeed
Neither CME or CUCM can play anything based on a schedule, a 3rd party is forcefully required. I suggest you reach your local Cisco representatives as they might be aware of vendors to do the above.
java
Dear,
It is clear that its not possible without third party application. Now i am only looking application which can be integrate with CME.
I can see the third party application like https://marketplace.cisco.com/catalog/products/3289
to play Azan using CUCM where CME is not mentioned.
Salem Amer
Hi Abdul,
Please check Athan Sip from Maathen , which registers to UC/IP PBX as soft phone extension and start auto paging based on  Azan timers .
I hope this help ...
