02-10-2019 03:00 AM - edited 03-17-2019 02:05 PM
Alright, so I've got a cisco 7962, a Cisco 8961, a Linksys spa9000 and I have a FreePBX server on the network These are all hooked up to a Cisco cataylist POE Then connected to the gateway. The Cisco 7962's ip is 192.168.0.10, I can access the web UI, but there's nothing to configure, therefore I cannot follow this videos instructions to register the phones to the PBX. My cisco 8961's IP is 192.168.0.15 but nothing happens when i try to access the web UI, just says 'refused to connect' even after using https:// and a factory reset. Both of the phones say "phone not registered". This is all for my CCNA class I'm taking at my High School, so it'd be pretty cool if I can get this all hooked up by the end of the year. All I'm trying is to call another phone on the LAN and be able to talk to each other, nothing too crazy. Any help would be greatly appreciated
02-10-2019 03:21 AM
Most like the 8900 is running Enterprise image.
02-10-2019 03:30 AM
@Leo Laohoo wrote:
@Wolfgang Badenhope wrote:My cisco 8961's IP is 192.168.0.15 but nothing happens when i try to access the web UI, just says 'refused to connect' even after using https:// and a factory reset.
How do you access the UI then?
02-10-2019 12:17 PM
02-10-2019 02:27 PM
With an enterprise image, what steps would i have to take to get this registered?
02-10-2019 09:42 PM
If this is meant for school, I'd rather step back and let the instructor do his/her job.
The steps I do and the steps the instructor(s) will explain will be significantly different and I don't want to ruin it.
02-10-2019 10:19 PM
02-10-2019 03:22 AM
have you look the FreePBX have wiki and have simple guide how to setup these phones to register with FreePBX
https://wiki.freepbx.org/display/FOP/Cisco
check supported device and tested also
https://wiki.freepbx.org/display/FCM/EPM-Supported+Devices
