06-09-2014 11:58 AM - edited 03-16-2019 11:03 PM
CUCM 9.1.2
I have a 2911 (MGCP) with an FXO card. The FXO port is configured and shows as registered but will not show up in the ports list in my route groups so that I can add it. Every other port from my other MGCP gateways shows up fine. Resetting the port and having it re-register did not help. Any ideas?
Solved! Go to Solution.
06-09-2014 01:30 PM
If the port is assigned to a route pattern, it wont be an option available under Route groups and vice versa. I would check depending records on the ports to see where its assigned and change it.
06-09-2014 01:30 PM
06-10-2014 07:59 AM
That was it. There was a pattern pointing directly at the port. As soon as I changed the pattern to point to a RL instead, the port showed up in the RG list. Thanks.
