02-20-2019 12:42 PM - edited 02-20-2019 01:11 PM
i have a cucm and a h323 gateway router and im supposed to route pstn calls to a sip trunk , i have been told h323 to sip might cause unnecessary problems so is it possible to create a sip trunk between my cucm and voice gateway router for incoming calls and a sip trunk between my voice gateway router and pstn access provider? like
cucm>sip trunk>voice gateway>sip trunk>sip server to pstn?
and create two dial peers
also assuming the cucm and the sip server is on the same subnet , on cucm and the sip server can i point the sip trunk to the same voice gateway interface ip address?
dial-peer voice 1 voip
description *to cucm*
destination-pattern ... ###internal extensions
session protocol sipv2
session target ipv4:*cucm*
voice-class sip options-keepalive up-interval 30 down-interval 60
dtmf-relay rtp-nte sip-notify
codec g711ulaw
no vad
dial-peer voice 2 voip
description *to pstn sip server*
destination-pattern ........ ###outside numbers
session target ipv4:*sip server to pstn*
codec g711ulaw
no vad
Solved! Go to Solution.
02-23-2019 11:42 PM
02-20-2019 01:33 PM
Hello there,
You can activate CUBE functionalities on your VGW by applying some configuration changes and obtaining CUBE licenses from Cisco depending upon your existing VGW model.
You may use the following as your reference; https://ucpros.net/cisco-sip-gateway-configuration/
Shalid
Please rate helpful posts.
02-20-2019 01:36 PM
I strongly suggest you review the CUBE sessions from Cisco Live to understand this.
02-20-2019 03:06 PM
You might want to review the CUBE sessions from Cisco Live for this.
02-20-2019 10:10 PM
You are trying to configure CUBE with both incoming and outgoing call legs to be Sip. This is definitely possible
02-23-2019 11:28 PM
what is the difference in configuration between a h323 gateway and a cube? isnt just a router with incoming and outgoing dial peers?
can someone post a basic cube config?
02-23-2019 11:42 PM
