Possible to disable a switchport if no Cisco phone is detected?
rpeasah
Beginner
Beginner
Is there a Cisco access switch feature to disable a switchport if a device is attached directly to the port and it is not a Cisco phone?
How? Can you give an example?
Leo Laohoo
VIP Community Legend VIP Community Legend
Here's a good explanation about AutoSmartPort:
Configuring Auto Smartports Macros
Amit23
Enthusiast
Enthusiast
you want to disbale from POE power that it is giivng when plug up ip phone
if you are plugging nay non ip phone device, for saving part use the commands:
under switch interface:
#int fa 0
# no poe power
exit
please check the commands for this aprt under interface.
Warm Regard's
Amit Sahrma
Recognize Your Peers
