02-18-2012 03:25 PM - edited 03-16-2019 09:39 AM
I've just migrated our PUB from 4.1.3 to 8.6.1 (via 7.1.5) onto new hardware with a new IP address for PUB.
Just wondering if there are any major post config changes I should be making given the pub has new IP address.
I've updated the extension mobility URL to match the new IP address of Pub.
I've also been through the Enterprise Parameters and checked that the new IP is listed where relevant and searched against the old IP (no instances found)
Any input would be appreciated.
Liam
Solved! Go to Solution.
02-19-2012 12:18 AM
Hi Liam
Typically it's just:
System/servers menu (may have hostnames or IPs)
Phone Services (i.e. em etc)
So it sounds lik e you have it covered!
Principal Engineer at Logicalis UK
Please rate helpful posts...
02-19-2012 12:18 AM
Hi Liam
02-21-2012 08:08 PM
Thanks for the feedback Aaron
