05-27-2013 06:39 AM - edited 03-16-2019 05:32 PM
Hello to all
I have a router Cisco 2821 and 4 analog lines in FXO ports , when i place a call from outside i heard the IVR but the hunt of phones not rings , here is the sh voice call stat
Router#sh voice call stat
CallID CID ccVdb Port Slot/DSP:Ch Called # Codec MLPP Dial-peers
0x1620D 613 0x4B0CECCC 2/0/8 0/1:1 9000 None 208/20186
0x16210 613 0x4CE25A04 50/0/2.0 *9000 None 20186/208
1 active call found
Router#sh dial-peer voice summ
dial-peer hunt 0
AD PRE PASS OUT
TAG TYPE MIN OPER PREFIX DEST-PATTERN FER THRU SESS-TARGET STAT PORT KEEPALIVE
100 voip up up 0 syst
101 pots up up 0[3-7]...... 0 down trunkgroup PSTN
102 pots up up 15 015....... 0 down trunkgroup PSTN
103 pots up up 0 00[3-7]T 0 down trunkgroup PSTN
104 pots up up 00 000T 0 down trunkgroup PSTN
105 pots up up 08 008T 0 down trunkgroup PSTN
106 pots up up 01[^5]. 0 down trunkgroup PSTN
107 pots up up 0911 0 down trunkgroup PSTN
108 pots up up 00[1-3].15......- 0 down trunkgroup PSTN
109 pots up up 00[1-3]......... 0 down trunkgroup PSTN
110 pots up up 00[1-3]...15....- 0 down trunkgroup PSTN
111 pots up up 00[1-3]..15.....- 0 down trunkgroup PSTN
20001 pots up up 9011$ 0 50/0/1
20002 pots up up 9002$ 0 50/0/2
20003 pots up down 0 50/0/3
20004 pots up down 0 50/0/4
20005 pots up down 0 50/0/5
20006 pots up down 0 50/0/6
20007 pots up down 0 50/0/7
20008 pots up down 0 50/0/8
20009 pots up down 0 50/0/9
20010 pots up down 0 50/0/10
20011 pots up down 0 50/0/11
20012 pots up down 0 50/0/12
20013 pots up down 0 50/0/13
20014 pots up down 0 50/0/14
20015 pots up down 0 50/0/15
20016 pots up down 0 50/0/16
20017 pots up down 0 50/0/17
20018 pots up down 0 50/0/18
20019 pots up down 0 50/0/19
20020 pots up down 0 50/0/20
20021 pots up down 0 50/0/21
20022 pots up down 0 50/0/22
20023 pots up down 0 50/0/23
20024 pots up down 0 50/0/24
20025 pots up down 0 50/0/25
20026 pots up down 0 50/0/26
20027 pots up down 0 50/0/27
20028 pots up down 0 50/0/28
20029 pots up down 0 50/0/29
20030 pots up down 0 50/0/30
20031 pots up down 0 50/0/31
20032 pots up down 0 50/0/32
20033 pots up down 0 50/0/33
20034 pots up down 0 50/0/34
20035 pots up down 0 50/0/35
20036 pots up down 0 50/0/36
20037 pots up down 0 50/0/37
20038 pots up down 0 50/0/38
20039 pots up down 0 50/0/39
20040 pots up down 0 50/0/40
20041 pots up down 0 50/0/41
AD PRE PASS OUT
20042 pots up down 0 50/0/42
20043 pots up down 0 50/0/43
20044 pots up down 0 50/0/44
20045 pots up down 0 50/0/45
20046 pots up down 0 50/0/46
20047 pots up down 0 50/0/47
20048 pots up down 0 50/0/48
20049 pots up down 0 50/0/49
20050 pots up down 0 50/0/50
20051 pots up down 0 50/0/51
20052 pots up down 0 50/0/52
20053 pots up down 0 50/0/53
20054 pots up down 0 50/0/54
20055 pots up down 0 50/0/55
20056 pots up down 0 50/0/56
20057 pots up down 0 50/0/57
20058 pots up down 0 50/0/58
20059 pots up down 0 50/0/59
20060 pots up down 0 50/0/60
20061 pots up down 0 50/0/61
20062 pots up down 0 50/0/62
20063 pots up down 0 50/0/63
20064 pots up down 0 50/0/64
20065 pots up down 0 50/0/65
20066 pots up down 0 50/0/66
20067 pots up down 0 50/0/67
20068 pots up down 0 50/0/68
20069 pots up down 0 50/0/69
20070 pots up down 0 50/0/70
20071 pots up down 0 50/0/71
20072 pots up down 0 50/0/72
20073 pots up down 0 50/0/73
20074 pots up down 0 50/0/74
20075 pots up down 0 50/0/75
20076 pots up down 0 50/0/76
20077 pots up down 0 50/0/77
20078 pots up down 0 50/0/78
20079 pots up down 0 50/0/79
20080 pots up down 0 50/0/80
20081 pots up down 0 50/0/81
20082 pots up down 0 50/0/82
20083 pots up down 0 50/0/83
20084 pots up down 0 50/0/84
20085 pots up down 0 50/0/85
20086 pots up down 0 50/0/86
20087 pots up down 0 50/0/87
20088 pots up down 0 50/0/88
20089 pots up down 0 50/0/89
20090 pots up down 0 50/0/90
20091 pots up down 0 50/0/91
20092 pots up down 0 50/0/92
20093 pots up down 0 50/0/93
20094 pots up down 0 50/0/94
20095 pots up down 0 50/0/95
20096 pots up down 0 50/0/96
1 voip up up [*1-9]... 1 syst ipv4:172.31.86.14
2 voip up up [*1-9]... 2 syst ipv4:172.31.26.37
23551 voip up up 2355 1 syst ipv4:172.31.86.14
23552 voip up up 2355 2 syst ipv4:172.31.26.37
AD PRE PASS OUT
200 pots up up 0 down 2/0/0
201 pots up up 0 down 2/0/1
202 pots up up 0 down 2/0/2
203 pots up up 0 down 2/0/3
204 pots up up 0 down 2/0/4
205 pots up up 0 down 2/0/5
206 pots up up 0 down 2/0/6
207 pots up up 0 down 2/0/7
208 pots up up 0 down 2/0/8
209 pots up up 0 down 2/0/9
210 pots up up 0 down 2/0/10
211 pots up up 0 down 2/0/11
213 pots down down 0 down 2/0/13
217 pots up up 0 down 2/0/17
218 pots up up 0 down 2/0/18
219 pots up up 0 down 2/0/19
220 pots up up 0 down 2/0/20
221 pots up up 0 down 2/0/21
222 pots up up 0 down 2/0/22
223 pots up up 0 down 2/0/23
216 pots up up 11599999 0 up 2/0/16
20186 pots up up 9000$ 0 50/0/2
Solved! Go to Solution.
05-27-2013 06:32 PM
-Can you please share the VoIP diagram?
-Also post the configuration.
-Where is connected the IVR?
You need to be more specific, so we can better understand the problem and give you a hand.
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
05-27-2013 06:32 PM
Jorge Armijo
05-31-2013 05:51 AM
Jorge , sorry for the delay
Finally the problem was some voice ports of SRST, the dial peer match them.
When I shutdown this ports the call can be completed !!!
Thanks a lot !!
