Pots lines and dial tone issue with telco
Chuck Reid
hello, we have been troubleshooting an issue with pots lines for several days with century link. It's a new turn up where an office moved to a new site. They have 6 pots line in a hunt group from telco which we have plugged in to two new fxo cards on a new router. We are told they are ground start lines and we have them configured for ground start. First, there is no dial tone, if you plug a line into a standard analog phone, there is no dial tone. Outbound calls hit the lines and the call appears to connect but the destination never rings. We worked with TAC for hours, trying every possible combination of commands. Telco is telling us that they do not provide dial tone which is completely foreign to my understanding of pots lines. Also, if we attach a butt set and ground the butt set, the butt set can place an outbound call. With all of the lines unplugged, telco told us the lines all showed in process busy or seized, even though we didn't have them plugged in. So this is all very confusing and we are now trying to have them switch the lines over to loop start. Can anyone make sense of this nightmare? Very confused with something that is normally so simple to set up.
Jonathan Schulenberg
Ground start lines are what you want because it's the only way to reliably know when the far-end has hung up and the router should go on-hook (i.e. Disconnect supervision).
You should escalate the ticket to a manager with the telco. The statement that they do not provide dial-tone is laughably wrong. If that were true then they have provisioned you on an FXO port on their CO switch which is not what you want (the Cisco router is supposed to be the FXO port, while the carrier is the FXS port). You want them to supply dial-tone with ground-start signaling.
Thanks, yes, they didn't seem to understand Cisco terms. They kept saying the lines are hunt lines so there is no dial tone. Also, in addition we had 4 FXS/DID lines operating in DID mode, so we never really figured out where the communication breakdown was, in the end, they changed the 6 ground start lines to loop start and they magically worked.
