Highlighted
Enthusiast
Power calculator tool
Can someone send me URL for Power calculation tool required for power calculation of 4500 switch for number of POE linecards support
8 REPLIES 8
Enthusiast
Re: Power calculator tool
Here's the link:
http://tools.cisco.com/cpc/launch.jsp
I think you'll need a valid CCO account.
Please rate useful posts..
Beginner
This tool is not listing out
This tool is not listing out most of the  phones while I am doing the power calculation. Is it an updated link ?
Hall of Fame Community Legend
Hi Bobby,
Hi Bobby,
Rather than list the phone models individually the calculator now lists the Power Classes down towards the bottom of the POE device page as shown below;
IEEE 802.3af Device - Class 1 (4W)
IEEE 802.3af Device - Class 2 (7W)
IEEE 802.3af Device - Class 3 (15.4W)
IEEE 802.3af Device - Class 4 (15.4W)
And then you can find out the power requirement for your desired models from the specific phone model data sheet. So for the 7800 series it is shown as;
The phone supports IEEE 802.3af PoE (Class 1); power consumption does not exceed 3.84 watts.
From;
http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/unified-ip-phone-7800-series/data-sheet-c78-729488.html
And if you were using 8851 and 8861 models you would use the following;
8851 -  IEEE Power over Ethernet class 3.
http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/unified-ip-phone-8800-series/datasheet-c78-731667.html
8861 -  IEEE Power over Ethernet class 4.
http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/unified-ip-phone-8800-series/datasheet-c78-731668.html
Cheers!
Rob
Hello ,
When we choose a device, then it gives 4-5 options. Which one to choose if I need to choose 9300-48P-A
Contributor
Yes, tim.giles is correct.
The Cisco® Power Calculator enables you to calculate the power supply requirements for a specific Power over Ethernet (PoE) configuration. The results will show output current, output power, and system heat dissipation. The Cisco Power Calculator supports the following Cisco product switching and routing platforms: Cisco Nexus 7000, Cisco Catalyst® 6500 Series, Catalyst 4500-E/4500 Series, Catalyst 3750-E/3750 Series, Catalyst 3560-E/3560 Series, Catalyst 2960 Series, Catalyst 2975 Series, Catalyst Express 500 Series, and the Cisco 7600 Series Router.
         "niLz"
Nilo Noguera Jr.
| Specialist, Virtual Engineering - Partner Helpline Organization
together we are the human network
"niLz" Nilo Noguera Jr. | Specialist, Virtual Engineering - Partner Helpline Organization together we are the human network
Hi Nilo,
Hi Nilo,
The tool you have mentioned is quite outdated, is there any up-to-date power calculator available?
Kind regards, Andrew C.
Collaborator
Hi Andrew,
Hi Andrew,
I just checked the tool using the same link:
Guess this should be an updated one as its also listing Nexus switches.
Rajan
Beginner
Re: Hi Andrew,
How much watt of UPS i should order for C9300-48U-A with
a. one 1100 watt power supply
b. two 1100 watt power supplies
c. one 1100 watt + 1 350 watt power supplies
Any answer would be really appreciated.
Content for Community-Ad
July's Community Spotlight Awards
