Prefix code dialling within the same cluster of CUCM
chingkiatlee
I would like to, if all to cisco ip phone is registered to the same cluster of cucm.
is it possible to definated them to call each other by using the prefix code?
Example:
Phone A call to Phone B by using 4 XXXX
Phone B call to Phone A by using 5 XXXX
But phont A & Phone B is register under same cluster of CUCM?
Take a look on CUCM SRND to unterstand the concept:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/8x/dialplan.html
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
Leonardo Santana
Yes its possible to use site code dialing to your dial-plan.
Leonardo  Santana
Leonardo Santana
Basically what should i do in the dial plan?
Leonardo Santana
Leonardo Santana
Hi Leonardo,
Thank you and appreciate it.
