Community Helping Community
817
Highlighted
Beginner
Prerequisites for upgrade UCM 8.6(1a) on MCS 7825-H3
G'day,
Planning to upgrade our Cluster to 8.6(1a). Cluster consists of several MCS 7825-H3 (HP OEM). I noticed the following on Page 5 of Release Notes for Cisco Unified Communications Manager Release 8.6(1a):
"If you are upgrading software on HP7825H3 or HP7828H3 hardware, ensure that you have a 16GB
USB device available to migrate your data to the new system."
Does anyone know what file system type the 16GB USB device needs to be formatted with. I can confirm that NTFS does not work.
Thanks in advance.
Col
1 ACCEPTED SOLUTION
Beginner
Hi Colan,
When following the same procedure to upgrade a cluster, do I need the external HD for both PUB and SUB? I have this question because the PUB and SUB servers are located in different cities and I like to make sure the external HD is ready if it's required for SUB as well.
Thanks.
Michael
4 REPLIES 4
Beginner
Upgrade to 8.6 worked just fine once I formatted the 16GB USB device to ext2.
Now if only I could work out how to rate this answer to my own question and close the Discussion
Beginner
Hi Colan,
Thanks.
Michael
Beginner
Yes you need to have external 16GB USB device formatted as ext2 connected when you upgrade each HP7825H3 or HP7828H3.
Beginner
Thanks Colan, +5.
Content for Community-Ad
FusionCharts will render here
