07-29-2010 10:43 AM - edited 03-15-2019 11:59 PM
I downloded the POstgres databse windows installer and have installed it on a seperate server.
I followed the Doc from Cisco but I get this error.
Verify external database server connectivity (database connection check):
The following CUP node to external database server connection(s) failed:
Solution:
Verify the hostname, username, and password are valid
Well they are??
HOst i put the IP, 10.10.10.18
Any help? Username is right since i can login on the server itself.
Solved! Go to Solution.
01-11-2011 12:15 AM
After 2 days of time wasting , I tried lordshawn 's method and it finally worked...
Try creating an admin user in windows named tcuser and it should help
07-29-2010 10:46 AM
So two days of hacking i got it to pass. I made a user account named "TCUSER" on the windows server with ADMIN rights. That WAS NOT in the documentation!!!!!!!!
01-06-2011 08:21 PM
Can you elaborate on the TCUser? I have getting the same error message and I am sure the hostname, username and pas
sword are correct.
Did you create a TCUSER as a database login user? if so, what rights did you give them. Did you use the default database postgres?
Thanks for your help.
01-11-2011 12:16 AM
check this link for tcuser...
you should alter tcuser as superuser in the db which you create..
11-12-2014 11:16 PM
I am also facing the same issue, need help. I have installed PostgressSQL 9.0 and 9.3 on my Laptop. While connecting database from Presence Server, putting Hostname as my Laptop's IP address.
01-11-2011 12:15 AM
01-11-2011 08:16 AM
Yup that works. Glad someone else found this post!
09-12-2011 02:13 PM
You must edit the pg_hba.conf file to allow connections from your CUPS server. Without this you will get the "
Verify the hostname, username, and password are valid" error.
While this is documented it is not completely clear as documented on this page:
