06-11-2013 07:09 PM - edited 03-16-2019 05:49 PM
Hi guys,
I receive this error every time I perform a Presence Backup...any idea?
I got a cluster with 2 servers and the System version is 9.1.1.10000-8
Server : CR1PRD108
Feature : IM_AND_PRESENCE
Component : CUP
Time Completed: 2013-06-12-10-16-08
Result Code : 1-Please check the component logs for further details.
Result String : ERROR
ready for backup
----> BEGIN Standard Output
----> END Standard Output
----> BEGIN Standard Error
Traceback (most recent call last):
File "/usr/local/sip/drf/epas/bin/cup_pre_backup.py", line 66, in ?
REQUIRED = REQUIRED + getDirSize(os.path.join(BASEDIR, dir))
File "/usr/local/sip/drf/epas/bin/cup_pre_backup.py", line 58, in getDirSize
os.path.walk(dir, calcDirSize, sizes)
File "/usr/lib/python2.4/posixpath.py", line 290, in walk
func(arg, top, names)
File "/usr/local/sip/drf/epas/bin/cup_pre_backup.py", line 48, in calcDirSize
stats = os.stat(os.path.join(dir, file))
OSError: [Errno 2] No such file or directory: '/usr/local/sip/.security/proxy/trust-certs/.0'
----> END Standard Error
Server : CR1PRD108
Component : CUP
ready for backup
10-22-2014 12:50 AM
Did you find out how to solve this problem? We have the same trouble after updating the CUP certificates.
Thanks!
06-15-2015 03:20 AM
the error message '/usr/local/sip/.security/proxy/trust-certs/.0' can only be fixed by cisco TAC.
They have to go on the CLI with root access to delete a position in the trust store, which starts with .0
There is no workaround you can fullfill, like renewing certificats or resarting drf services
Regards Michael
