Presence status between IP Phone and LYNC client
mahmoodmkl
Level 7
Level 7
Please i need your support to guide me how can we exchange ths presence status between cisco IP Phone and lync client.
5 Replies 5
I think i didnt put the question correctly.
I am looking for any feature or how can we exchange the presence status with LYNC.
i mean if i pick my IP Phone and start making a call the LYNC show change my status to either busy or on a call.
I understand that there needs to be some sort of integration and i am looking for the requirements for this integration.
Chris Deren
You will need either IMP integration with RCC or cuci lync.
Chris
mahmoodmkl
Level 7
Level 7
Hi Chris
Thanks for the reply.can u please eloborate more abt imp n rcc
Sent from Cisco Technical Support Android App
RCC - Remote Call Control, works but not recommanded by neither CDW or MSFT, requires CUPS/IMP server for server level integration
CUCI-Lync - Client based integration, requires running plugin which it does not seem you are going after.
HTH,
Chris
