Pressing 0 Busy Signal & Dumping Call
techdirectfcps
I am taking over the role as Director of Technology for our school system. The office phones in the schools are set up for when a person presses 0 it should ring and go to voicemail if no one is there. One of our schools is not doing this. It puts you on what seems like hold for a time then dumps the call out to a busy signal. Is there a setting on the phone or programing side I need to adjust? The more help the better. Thanks!
R0g22
A bit more detail would be helpful ? Products/devices in use etc ?
The phone that is having issues is the same phone being used at the other schools. It is a Cisco IP Phone 7960. I do have access to our call center and voicemail set ups. I've looked at the settings and they look similar to the other schools, but I may have missed a setting. Thanks
You have CUCM/CME and CUC/CUE for IP Phones and VM ?
Is the "it puts you on hold for a long time" about 15 seconds? If so, you may be running into a dialplan issue where you have more than one object that starts with a "0".
Check the translation pattern for "0" for that site. Make sure:
Urgent Priority - Checked
Partition - Is one that those dialing 0 have access to
Calling Search Space - Is one that reaches wherever the call is supposed to go
If these are still in place, you may need generate a trace file containing the call, then post it here and we can help you parse it.
