Prevent transfer of calls to an extension
juan.mejia
I explain the form:
From a 666 extension with local calls, the call can not be transferred to extension 665.
Greetings.
The only way to achieve that is to make sure your CSS cannot reach 665, or whichever DN you wan't to prevent calls from being transferred to.
There is no separate CSS for transfers, you use the same CSS for calls, which means you would be removing the ability to call that DN all together.
java
if this helps, please rate
Aeby Vinod
Level 3
Level 3
Can you call 665 normally from 666, if not could a CSS/Partitions config issue. If you can call then please describe what you experience when you try to do the transfer.
Aeby
Please rate if you find this helpful.
Aeby
I wrote wrong my problem the call must not be transferred.
Regards.
java
