Pri and Significant Digit
pharden
I have a range of 200 DID numbers. 2200 thru 2399 I am programming Two PRI's how do I tell the first PRI to accept a call from 22XX and /or 23XX and visa versa for the second?
thisisshanky
Level 11
Level 11
Are you trying to send an outbound call from phone 22XX out PRI#1 AND 23xx OUT pri#2 ?
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Chris Deren
You cannot, inbound calls are controlled by the Telco, you need to let them know which PRI you want to associated the DID range with. Usually when you have 2 or more PRIs terminated at the same location you arrange Trunk group with the Telco where they send calls on both PRIs, depending which one has available ports.
HTH,
Chris
