Walkthrough Wednesdays
654
satish rawat
Beginner
PRI calls failing in SRST/H323 mode
I have a 2921 VGW that has a PRI , everything works on MGCP mode, if i fail it to SRST or convert completely to a H323 calls out to PRI and inboud are failing. attached are detailed logs of isdn q931 and debug voip ccapi all.
What is interesting is when calling out to PRI ( in H323) there is no activity on q931 debugs...which is very strange...pots dialpeers are correct and shows that the dial peer is matched in debug ccapi. Inbound on PRI shows call hiting B channel on PRI and then fails with a unique message that says duplicate setup.
L3_GetUser_NLCB: DUPLICATE SETUP, message ignored
logs attached. This issue has my mind jolted ...i can think beyond a ios issue.. any input will be appriciated.
4 REPLIES 4
jagadish-g
Beginner
Just see / cross check these commands  in your voice gateway...
ccm-manager fallback-mgcp
application
global
service alternate default
dial-peer voice 2 pots
translation-profile incoming LD-OUT
destination-pattern 0T
incoming called-number .(dot)
direct-inward-dial
port 0/2/0:23
forward-digits all
Also to cross check what is your/users Voip number (4 or 5 or 6 digit) and what is your PRI Board number or your DID??
Jagadish
ronpatel
Collaborator
Hi Satish
What is your IOS on gateway. Below is bug related to your problem.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsj14460
regards
Ronak patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
That bug is on ver 12.4 this is 15.0...
Satish..
From the logs, it look slike the call is looped. When extension 4002 calls 919....The call appears to come back from 919...to 4002. Does this happen only to this extension or does this affects all calls in SRST
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Content for Community-Ad
Spotlight Awards 2021
