PRI Clocking Question - 2911 Router
Yort Mantup
Level 4
Level 4
I have three card types
card type t1 0 0
card type t1 0 1
card type t1 1 1
Clocking in currently configured as
network-clock-participate slot 1
network-clock-participate wic 0
no network-clock-participate wic 1
network-clock-select 1 T1 0/0/0
Controller T1 0/0/0 , T 0/0/1 and Controller T1 1/0 and 1/1 are used for our 4 T1 connections (MPLS)
I want to add a PRI to controller 0/1/0. When I try and configure the controller for the PRI I get the following:
rtr-2911 (config-controller)#pri-group timeslots 1-24 service mgcp
%Please configure network-clock-participate wic 1 first
%Insufficient resources to create pri-group - it has been removed
How do I go about configuring the clocking correctly to allow for the PRI?
2 Accepted Solutions
Ah.. got it.  As far as PVDM - I have two modules install PVDM3-16 and PVDM3-64
hw-module pvdm 0/0
hw-module pvdm 0/1
Please cnfigure this..
Conf t
voice-card 0
dspfarm
dsp services dspfarm
Then ensure you have
And then try and configure your pris again
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
6 Replies 6
mgbrown007
You will likely have to configure 'clock source independent' on the controller before adding the PRI group.  But however you modify it, make sure you have the clocking situation coordinated with the provider so there will be no conflicts or slips on the line.
Ayodeji Okanlawon
You cant configure PRI without cnfiguring network participate on the port. So you need to configure
%Insufficient resources to create pri-group---Means you dnt have enugh dsp to create the pris..You need to add PVDM to your router
hw-module pvdm 0/0
hw-module pvdm 0/1
But they have been allocated to something else..xcoding, conferencing etc..The gateway doesnt see any free resources,,
send me a show run and a show diag
I attached the the two to my previous comment
Conf t
voice-card 0
dspfarm
