PRI / DID Can not Call IP PHONE
KY_
Level 4
Level 4
I have a PRI line and i want to cofnigıre  444 XXXX  DID  number IPT Line
When I called 444 XXXX ,calls ring one time and end.
Ex: if outbound  calls PRI line , it should be ring 8945
Here is my voice gateway config
redundancy
controller E1 0/0/0
pri-group timeslots 1-31 service mgcp
controller E1 0/0/1
shutdown
framing NO-CRC4
clock source internal
ip ftp username ftpdestekhiz
ip ftp password 7 01425F570C1F14
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 192.168.5.201 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
isdn bind-l3 ccm-manager
isdn bchan-number-order ascending
isdn sending-complete
no cdp enable
interface BRI0/1/0
no ip address
isdn switch-type basic-net3
isdn point-to-point-setup
isdn bind-l3 ccm-manager service mgcp
interface BRI0/1/1
no ip address
ip default-gateway 192.168.5.254
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.5.254
ip route 10.10.10.0 255.255.255.0 192.168.1.253
control-plane
voice-port 0/0/0:15
echo-cancel coverage 64
cptone TR
voice-port 0/1/0
disc_pi_off
cptone TR
timeouts call-disconnect 5
timeouts wait-release 1
voice-port 0/1/1
voice-port 0/2/0
supervisory disconnect anytone
no vad
cptone TR
timing hookflash-out 50
timing sup-disconnect 1000
connection plar 4000
description TT_Line
caller-id enable
voice-port 0/2/1
no vad
cptone TR
description TT_Line
caller-id enable
voice-port 0/2/2
no vad
cptone TR
description TT_Line
caller-id enable
voice-port 0/2/3
no vad
cptone TR
description TT_Line
caller-id enable
voice-port 0/3/0
no vad
cptone TR
caller-id enable
voice-port 0/3/1
no vad
cptone TR
caller-id enable
voice-port 0/3/2
no vad
compand-type a-law
cptone TR
caller-id enable
voice-port 0/3/3
no vad
cptone TR
caller-id enable
voice-port 1/0/0
no vad
cptone TR
description TT_Line
caller-id enable
voice-port 1/0/0
no vad
cptone TR
description TT_Line
caller-id enable
voice-port 1/0/1
no vad
cptone TR
connection plar opx 4061
description TT_Line
caller-id enable
voice-port 1/0/2
no vad
cptone TR
description TT_Line
caller-id enable
voice-port 1/0/3
no vad
cptone TR
description TT_Line
caller-id enable
voice-port 1/1/0
no vad
cptone TR
description TT_Line
caller-id enable
voice-port 1/1/1
no vad
cptone TR
description TT_Line
caller-id enable
voice-port 1/1/2
no vad
cptone TR
description TT_Line
caller-id enable
voice-port 1/1/3
no vad
cptone TR
connection plar 4061
description TT_Line
caller-id enable
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 192.168.5.200
ccm-manager config
mgcp
mgcp call-agent 192.168.5.200 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp playout fixed 80
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
no mgcp explicit hookstate
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0
mgcp profile default
dial-peer voice 999020 pots
service mgcpapp
port 0/2/0
dial-peer voice 999022 pots
service mgcpapp
port 0/2/2
dial-peer voice 999021 pots
service mgcpapp
port 0/2/1
dial-peer voice 999030 pots
service mgcpapp
port 0/3/0
dial-peer voice 999031 pots
service mgcpapp
port 0/3/1
dial-peer voice 999032 pots
service mgcpapp
port 0/3/2
dial-peer voice 999033 pots
service mgcpapp
port 0/3/3
dial-peer voice 999023 pots
service mgcpapp
port 0/2/3
dial-peer voice 999100 pots
service mgcpapp
port 1/0/0
dial-peer voice 999101 pots
service mgcpapp
port 1/0/1
dial-peer voice 999102 pots
service mgcpapp
port 1/0/2
dial-peer voice 999103 pots
service mgcpapp
port 1/0/3
dial-peer voice 999110 pots
service mgcpapp
port 1/1/0
dial-peer voice 999111 pots
service mgcpapp
port 1/1/1
dial-peer voice 999112 pots
service mgcpapp
port 1/1/2
dial-peer voice 999113 pots
service mgcpapp
port 1/1/3
dial-peer voice 1 pots
preference 1
service mgcpapp
incoming called-number .T
direct-inward-dial
port 0/3/0
forward-digits all
dial-peer voice 2 voip
destination-pattern 4...
session protocol sipv2
session target ipv4:192.168.1.230
dtmf-relay sip-notify h245-alphanumeric
codec g711ulaw
dial-peer voice 15 voip
destination-pattern 4000
session target ipv4:192.168.5.200
dtmf-relay rtp-nte
codec g711ulaw
6 Replies 6
Chris Deren
Which PRI is the call arring on as your 0/0/0 is not configured with same framing as 0/0/1, and 0/0/1 is in shutdown mode.
Can you post "debug isdn q931" for the call?
Chris
sorry for wrong info,  DID come  via anaolog   line and it plugged FXO port voice gateway,
Call is ringing one time and it end, i can not receive debug q931 any log when i called 444 XXX number
but also  called other number i can receive debug
show voice call
1/1/2 -          -  -                     vpm level 1 state = FXOLS_ONHOOK
vpm level 0 state = S_UP
calling number 05xxxxxxx, calling name , calling time 06/05 14:49
1/1/3 -          -  -                     vpm level 1 state = FXOLS_ONHOOK
calling number 77777 , calling name , calling time 05/30 13:52
Are you sure the ports are loop start and not ground start?
Can you provide screen shot of port 1/1/2? Do you have attendant destination defined? What is it pointing to?
Does the CSS applied to this port lists partition assigned to the destination DN?
Chris
port 1/1/2
voice-port 1/1/2
no vad
cptone TR
description TT_Line
caller-id enable
This is my working call process output
VGW01(config-voiceport)#
Jun  6 16:57:39.871: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x1634
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98382
                Exclusive, Channel 2
        Calling Party Number i = 0x0081, '0555555555'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0xC1, '777777'
                Plan:ISDN, Type:Subscriber(local)
        High Layer Compat i = 0x9181
Jun  6 16:57:39.883: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x9634
Jun  6 16:57:39.883: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8  callref = 0x9634
        Progress Ind i = 0x8088 - In-band info or appropriate now available
Jun  6 16:57:45.711: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x1634
        Cause i = 0x8090 - Normal call clearing
Jun  6 16:57:45.727: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x9634
Jun  6 16:57:45.743: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x1634
But when i call 444 7777 number i can not receive any debuq output  with debug isdn q931
Not CSS and partion assigned any number,
because our local DN configure not assign CSS/Partition
When i called 444 7777 number one time call and called number connected bbut calling number end a few second lated disconnected
i think problem is  related FXO port because i did configure loopstart and groundstart FXO  port
When i configure loopstart,port  auto answer and call is is immidiately end, if i configure groundstart , i hear ring tone but DN is not ringing,
Check your cable polarity, reverse the pair as ground start signaling is polarity sensitive.
Are you saying that in CallManager all DNs are in none partition?
Chris
