pri-group timeslots 1-31
kp-tkr2014
Hi, What does it mean if we did not mention any service with pri group ( pri-group timeslots 1-31 ) Thanks
@Syed
Level 3
Level 3
It is only required when you want to confirgure mgcp on the router otherwise is it not required
HARIS_HUSSAIN
1) We have only Option to specify MGCP
DXB-FTA-VG-01(config-controller)# pri-group timeslots 1-31
%Voice interface must be shutdown before updating.
DXB-FTA-VG-01(config-controller)# pri-group timeslots 1-31 ?
nfas_d Specify the operation of the D-channel timeslot.
service Specify the service type
<cr>
DXB-AA-VG-01(config-controller)# pri-group timeslots 1-31 s
DXB-AA-VG-01(config-controller)# pri-group timeslots 1-31 service ?
mgcp Media Gateway Control Protocol service
So don't specify MGCP means that ISDN L3/L2 signalling is terminated on the Router Else with MGCP l3 Signallin is terminated to CUCM.
Hope that clarifies the question
Do remember to rate and mark correct as applicable
